Brembo setup 08-09 Touring (front and back)(fits 0608 VROD too)
SELL PENDING (on hold until June 5th for member)
Purchased some new take off Brembo parts to convert my Dyna FXDF to Brembos a couple months ago. Installed calipers and they worked perfectly, but need a 310-320mm rotor instead of the factory 300mm. There was a slight overhang of the pad contact on the disc that I wasn't comfortable with for the long term. Used a couple hundred miles, then regretfully converted back to the stock setup. I only used the front calipers with my conversion. I believe these pieces will fit the 08-09 Touring and some of the pieces will fit the 06-08 VROD too. Please verify before purchase.
2 HD Brembo front calipers (L/R) installed with Lyndall Racing 7254 ZPlus pads (~200 miles on pads)(I painted the silver screen black)
Chrome HD bango bolts (extra upgrade) for front calipers
1 HD Brembo "rear" caliper - with new pads (new takeoff, not used by me)(no bracket)
2 HD Touring rotors 41809-08 and 41808-08 (slightly used takeoffs - not by me)
Master cylinder - front with lever
Clutch lever
lever clamps (2)
Switch housing for touring (4 pieces - no guts inside)
Will probably need to get some caliper mounting bolts to mount (I had to in my case)
I also have a PDF file created by a member on one of the forums that is extremely useful, I can email if you want to see install process.
Pictures show all the pieces, everything is in great shape
Have over $500 invested in this setup - will take $300 shipped (lower 48 only)
shipping weight ~25# in 12x12x6 box
email - reesmicm@***.net in case I miss you on the forum
thanks,
Mike
Clutch lever
lever clamps (2)
thanks,
Mike
brembos
There is no comparison between the older HD brakes and their new style HD Brembos, the old style are as effective as putting your feet down to stop like the Flintstones. The next best thing is to have ABS with Brembos.
I have one person on the hook for these shocks, I am holding them for him until he gets back in the country June 5th. He was the first to contact me. If he decides against getting the brembos, I will post a note on this post.
I'm guessing that was a typo... Interested in the Brembo brakes, if he backs out. Thanks, Shaun
THVNDER
01-02-2018 11:13 AM
Maximus924
06-25-2016 05:25 PM
being cheap- other hd family calipers that match the stock 2013 fxd bolt and rotor coverage pattern?
cvaria
03-26-2016 07:55 AM
