Mark this thread as Unsold
Road Glide/RG3 Freedom Shields Windshield 2015-2023
This windshield is so much better than stock.
Will fit 2015-2023 Road Glides and RG3 as well as 2024 Road Glide Limited.
It is Light Gray Tint.
From the Freedom Shields web site:
• Freedom AirCurve design – our recurve drives the airflow 2″-3″ higher than a standard windshield
• Cleaner air flow – less wind noise & turbulence for the rider and passenger
• Helps to stabilize the bike at higher speeds
• Allows you to use a shorter windshield for a better view over the top without sacrificing comfort or use the same size or taller windshield for added comfort.
• 30% thicker than the stock windshield and other windshields for more stability and added strength
• Crystal clear optical clarity – No distortion !
• High Gloss, hand polished edges
• All mounts are holes (no slots) for added strength and a cleaner look
• High quality painted Black mask at the base of the windshield
• Best quality, performance, optical clarity, fit and finish in the industry
This windshield has some minor surface scratches that are barely noticed, as a result of road dirt hitting the windshield. Absolutely does not affect performance.
It is a 15 inch windshield and using the picture and chart below, you can determine the actual height on the bike.
(The Bar ‘n Shield/Shark decal can be peeled off if you wish)
It is $260 new.
Asking $140 shipped to Lower 48 and Canada.
It is $260 new.
