Mark this thread as Unsold
*Twin Cam Case & Crank* for your next motor build!! $375
I have the stock black Harley 103 twin cam case and crank/rods. Crank run out is just over .005 (5 thou) which is still in-spec and usable (but not perfect). If you blew up your bottom end and need something for cheap, here you go! Or if you’re looking to build a big motor, this is the perfect base for you to start your big motor build without having to pull your existing motor out of your bike! That way you can build this motor and still enjoy riding in the meantime. Personally I would send the crank off to dark horse to have it true and welded so you know you have a bulletproof bottom end, then build up big from there! $375 firm plus $75 shipping CONUS.
venturaoutfit
Softail Parts
10-25-2012 12:44 PM
