Plug and play, with dealership or indy activation, used 3K miles before trading in on 23 CVO. Easy to install, M8 touring bikes are already wired for it, pulls a lot of air through the oil cooler lowering oil temps. Retails for $275,
Traffic jam? This Oil Cooler Fan can help keep Milwaukee-Eight engine oil temperature under control if you find yourself idling or moving slowly in traffic, especially in hot weather. Fan automatically engages to lower oil temperature up to 50 degrees compared to an oil cooler without a fan. Weather-proof for durability.
• Perfect addition to a bike equipped with high performance components
• Ideal for bikes that see parade duty and other low speed or continuous idle situations
• Fan automatically engages when the engine oil temperature rises
• When in operation the Oil Cooler Fan can provide up to a 50 degree drop in oil temperature compared to an oil cooler without a fan
• Utilizes weather-rated fans and electronics that are designed reliable service in the harsh motorcycle environment
• Engineered for bolt-on installation and plug-and-play compatibility with your bike’s wiring harness without unhooking messy oil lines
• ECM reprogramming by a Harley-Davidson® Dealer is required to complete the installation
• No splicing or rewiring is required
You take it to the dealer & they will flash it and turn it on. It uses the sensors on the motor to turn it on/off. . Or if you have the Dynojet Power Vision, you can turn it on using that.
