Thundermax ECU 17-20 Touring
Have been using this for about a year and had great results and power increase. I am selling my bike and putting it back to stock so selling all upgrades. Looking to get $600. Thundermax says that the procedure for pairing with new bike is simply changing the vin when doing the setup. Includes wide band oxygen sensors. These are just shy of $1100 on their site.
From Thundermax website.Every degree and a half of throttle; every 256 RPM, there is a fueling point that is automatically adjusted. That means more control and a smoother running engine. With the built in barometric sensor you never have to think about ambient air changes. WideBand O2 sensors constantly read the Air Fuel Ratio and give live, real time feedback to the ECM. That means, no “accepting” the changes made to the map, once you key off the changes are written. The ThunderMax ECM is fully adjustable with our ThunderMax tuning software or can be used just by loading a basemap. The choice is yours.
ThunderMax is an industry award winning, performance ECM designed specifically for EFI equipped Harley Davidson® motorcycles. This highly advanced, stand-alone tuning system utilizes proprietary AutoTune technology with wide-band oxygen sensors to deliver unmatched performance and rideability. ThunderMax comes 100% assembled, ready to install with no wire-cutting or splicing required. Simply replace the factory ECM and oxygen sensors, load a map, and enjoy your new ride!
600 foa a gently used T max is a very fair deal and if the new owners bike is a close set up then the Auto tune can make adjustments, or someone real good with the programing can do it manualy or add in their tune. That unit is flexable like that. Good luck with parts clearance sale
I listed a Badlander for 97-07 here but never had a nibble. I reckon some parts just sell better than others
Thanks for your feedback, I felt it was a decent deal too for someone, I am not trying to recoup all the money spent on the bike but only some of it.
When you set it up for the first time you have option of choosing one of many base maps, you just choose the one that is the closest to your set up and then tide the bike, it will then calibrate to your bike and just keep getting more precise the more you ride, pretty cool how this works.
Initial setup is really easy too and Thundermax support is really good too if you happen to run into problems.
dfixit1 (12-11-2023)
IBlameTheDog
12-09-2023 08:14 PM
