Mark this thread as Unsold
FS:Harley chrome batwing pre wired mini apes for 14-23 Touring
$250 shipped to lower 48 CONUS only. These were taken off the bike and only had 2000 miles on it when I bought the bike so they are in very good condition.
Took these of my 21 Tri Glide I just purchased. I like taller apes. These are pre wired but you will need to pull your throttle wires. If you have cable throttle the disregard. They may fit other bikes but I am just going off of what I saw on the HD website for these. Part #57474-11. The wires will fit 2014-2023 the actual bars will fit down to 09 but the wiring won’t because it changed in 14. Below is the description of the bars only, I have stock clutch and brake lines on my bike. These list as 12” rise but are not high like a 12” ape hanger. Your hands are at or slightly below the top of the fairing.
Fits ABS enabled '09-later Electra Glide®, Street Glide®, Ultra Limited™ (except '10-'13 FLHTK) and Trike (except FLRT) models. Does not fit CVO™ models. All models require separate purchase of additional components for installation. '09-'13 FLHX and models with fairing-mount mirrors require separate purchase of handlebar-mounted mirrors and Fairing Plugs. Does not fit with stock heated grips or accessory Black Rubber Heated Hand Grips P/N 56100034.
Base Width: 16.0
Base Width UOM: Inches
Knurl Center-to-Center: 3.5
Knurl Center-to-Center UOM: Inches
Diameter: 1.0
Material Diameter UOM: Inches
Sold Separately: Additional installation components
Sold In Units: Each
Material: Steel
In the Box: Handlebar and bushings
Pullback: 1.75
Pullback UOM: Inches
Rise: 12.0
Rise UOM: Inches
Tip-to-Tip: 35.0 inches
NOTES: Installation of some handlebars and risers may require a change in clutch and/or throttle cable and brake lines for some models. Handlebar height is regulated in many locations. Check local laws to ensure your motorcycle meets applicable regulations.
please ask questions if you have any.
Base Width: 16.0
Diameter: 1.0
Sold In Units: Each
Material: Steel
Pullback: 1.75
Rise: 12.0
Rise UOM: Inches
Goose_NC (11-12-2023)
