Mark this thread as Unsold
Eagle infinity beam 7” chrome and spots
The Eagle Lights IB7BPK is the highest output LED headlight and LED passing light kit. These matching lights provide a brighter crisper and whiter light that is 6000K. This light output is the closest to the color temperature of daylight, dramatically improving light projection distance and overall visibility.
Infinity Beam Series Features: The Eagle Lights Infinity Beam Series represents the best in Complex Reflector technology. It features two sets of complex reflector regions for high beam and low beam. The reflect lens located in the back of the light is specifically shaped to maximize draw distance for the beam pattern. Never go dark and stay safer with an Infinity Beam LED headlight.
- NEW HORIZON BEAM PATTERN- The Horizon Beam Pattern is the new standard for LED headlights. It is the farthest reaching beam pattern available. Perfect for cruising down old, long country roads or dark highways. The low beam provides a wide beam pattern with a DRL flood light and advanced complex reflection optics. The high beam pattern is a long reaching light allowing you to see extremely far down the road.
NEW CASE DESIGN- With advanced cooling heatsink, the light runs cooler and will last longer. The custom heatsink shape is designed for maximum cooling efficiency with a slimmer design. The slimmer heatsink design allows Indian and Harley motorcycles to use the headlight without an adapter ring.
PLUG AND PLAY - Ready to use out of the box! No splicing, no wiring, no capacitors, just ready to use. We build everything needed inside the headlight so you don't have to wire it. Comes with the standard 3 prong H4 connection and has high and low beam, all in one headlight.
DUAL COMPLEX REFLECTOR - With dual complex reflectors and a built in DRL, the light pattern is shaped to be perfect for riding. The low beam and high beam provide a bright white light that is 6000K.
$125 shipped headlight and spots
