Fox Street Performance Rear Shocks
You are priced fair - now you are waiting for a solo-Rider on the lighter side of the scale for the standard springs - I just put on new shocks about 6 months ago or i would be twisting your arm to make a deal on these Fox shocks
porkster (03-23-2023)
Here’s what Fox said when I asked about the weight
”At your weight of 190lbs, the standard spring setup is ideal. Even with your wife as passenger your weight would only be slightly above the standard maximum weight limit of 280lbs.
The heavy duty starts off 240lbs which would great if you’re only riding two up all the time however fairly stiff if you ever rode alone.”
HM_SanDiego (03-23-2023)
