Mark this thread as Unsold
Red Shift 468 Cam from Zippers Performance
I have a used RS 468 cam with 17k miles on it. Normal signs of wear. I change oil every 5k with full synthetic. I will also throw in a new cam bearing. Fits all M8 motors. This was a great stage 2 cam, but I'm upgrading to stage 4 with a different cam.
Full retail is $299.95.
Asking $160 plus shipping.
Designed by Zipper’s engineering, the RS 468 delivers significant improvements in power and throttle response right where you ride. The Red Shift 468 is designed to complement the 4-valve heads’ high intake flow while its unique design overcomes the restrictive exhaust port for big gains in both torque and horsepower. The RS 468 provides instant acceleration below 2,000 RPM while pulling strong to 6,000 – this cam really shines in the primary 2,000-4,000 RPM cruising range.
Leimy (03-02-2023)
$150 shipped. I've got this boxed up with a new S&S cam bearing, assembly lube, and cam chest o-rings. This is a great cam for a budget stage 2 build.
RoadKing966 (10-09-2023)
