Mark this thread as Unsold
16 FLHXS Hand-Adjustable Rear Shocks
Took these off at about 4,000 miles total a few years back, just found them in my garage. $225 shipped OBO
P/Ns# 54000081 and 54000082
I just installed a set of these yesterday on my 2008 FLHX that had the original air shocks on it.
Fantastic upgrade for those wondering. Easy peasy install as well.
GLWS OP!
GLWS OP!
Yeah it was easy. Take off the saddlebags, jack the bike up, remove the two 3/4" bolts on each of the old shocks, remove the air lines and valve, set the adjustable shock to the lowest setting, loctite the bolts, raise / lower the jack to line up the bolt holes, torque them to 35 ft lbs, lower the jack, turn the adjuster to 16+/- clicks depending on your weight,and go ride!
Took me about 20 minutes start to finish.
Watch out for fluid running out of the air line push fitting in old shocks if you lay them down.
Probably could be done without a jack with a couple of extra hands to raise /lower / steady the bike.
GLWS OP!
GLWS OP!
bobter3 (07-16-2021)
Bluemax2
Touring Parts
09-07-2020 11:04 AM
