Magnum Shielding Sterling Chromite II 24" ABS Upper Brake Line AS37124
For Sale: Magnum Shielding Sterling Chromite II 24" ABS Upper Brake Line AS37124. Was installed on bike for only a couple rides and then switched out for a longer line for taller bars. Works perfectly and in excellent condition. You will need two copper crush washers to install (available at your motorcycle shop for cheap). Please note the length and part #. Please visit Magnum Shielding to make sure this will fit your motorcycle. This was installed on a 2021 Road King with ABS. Please note, you will need the mid-brake line for installation. This is for the upper line only.
Asking $38 shipped.
**I have a set of Magnum Caliber 16" apes for sale as well. If you buy those I'll throw in the brake line for free**
From Dennis Kirk's Website (where I purchased):
Magnum Custom Sterling Chromite II Designer Series ABS Upper Brake Line - 35°, 10mm, 24 in. - AS37124
Asking $38 shipped.
- ABS Touring models utilize both an ABS Designer Mid-Line Brake (PART NO. 19-10422) and a Designer Series Upper Assembly Brake line to complete the upper line from ABS Controller to master cylinder.
- All fittings are chrome and are available in 35° banjo angles to insure a great fit.
- ABS 2014+ Touring models Designer Mid-Line Brake Lines measure 64 in. from end to end.
- Any additional length needed for application changes will be added to the Upper Designer Brake Line.
BillinSC
03-26-2013 08:12 PM
