Mark this thread as Unsold
== Harley Davidson Touring Digital Suspension Air Pump ==
What you see is what you get.
HD Touring Digital Suspension Air Pump Kit # 54000033
I just installed a new 2032 Battery and it works great.
I will put the factory plastic back in battery hole to stop any battery drainage.
Comes complete with box (stains), box foam and instructions.
It looks and works as new.
I have adjustable shocks and no longer need this.
$59 shipped in the Lower 48, and I will eat the Paypal fees and the Priority Mail shipping too.
https://www.wisconsinharley.com/harl...auge-54000033/
Harley-Davidson® Digital Touring Suspension Air Pump, 54000033. For use with Touring air suspension components. Air pump conveniently adjusts air pressure in Touring shocks anywhere on the road. Easy to adjust air pressure in your Touring shocks anywhere on the road. Digital display for checking and altering pressure in the rear air shocks on all Touring motorcycles. Gauge can also be used to measure air pressure in your tires. Features Micro bleed valve that allows precise adjustment of air pressure, and the œno loss air connector maintains shock pressure when the fitting is removed. Display units can easily be changed between PSI and Kpa. LCD readout operates on a long-lasting, replaceable lithium coin-type battery (CR2032 3V, P/N 66000107). 1 year limited warranty. 54000033
- Harley-Davidson® Digital Touring Suspension Air Pump
- Adjust air pressure in your Touring shocks anywhere on the road
- Gauge can also be used to measure air pressure in your tires
- Digital display for checking and altering pressure in the rear air shocks on all Touring motorcycles
- Features Micro bleed valve that allows precise adjustment of air pressure, and the œno loss air connector maintains shock pressure when the fitting is removed
- Manufacturer Part Number: 54000033
NOW $55 shipped in the Lower 48, and I will eat the Paypal fees and the Priority Mail shipping too.
tjconnection (02-02-2020)
