Best grip glue
Old 09-20-2018, 11:14 AM
Quik's Avatar
Quik
Quik is offline
Received 2,577 Likes on 1,527 Posts
Default Best grip glue
Had my left arlen ness grip twist loose, what have you guys had the best luck with as far as grip glue goes, had these installed at Daytona bike week this year at the ness tent and whatever he used must be no good. Thanks!
Old 09-20-2018, 11:18 AM
mmesa005's Avatar
mmesa005
mmesa005 is offline
I have good results with this stuff!
Old 09-20-2018, 11:49 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,339 Likes on 3,186 Posts
Aqua Net
Old 09-20-2018, 02:39 PM
lionsm13's Avatar
lionsm13
lionsm13 is offline
Received 75,715 Likes on 22,721 Posts
Originally Posted by RANGER73
Aqua Net
That and grip tape should do it nicely.
You could also get a pair like HD's "Defiance" grips or the "Get a grip" or Avon's as none of them need glued.
Old 09-20-2018, 04:08 PM
Spartanden's Avatar
Spartanden
Spartanden is offline
Received 8,297 Likes on 6,040 Posts
I used to wrap white medical type adhesive tape on the bars....then pour lighter fluid in the grip and "slosh" it around to coat the internal surface with the lighter fluid. I would pour what was still in the grip on the bar covered with tape. Then slide the grip on and position. The lighter fluid has a chemical reaction with the adhesive on the tape and make things really tacky and sticky. Once it dried, the grip was on pretty solid. Now this was done on the rubber grips on my dirt bike. My Street Glide are held on by the clutch perch. I would do this if I felt movement with my current Avon grips.
Old 09-20-2018, 04:14 PM
Hammerhead Pat's Avatar
Hammerhead Pat
Hammerhead Pat is offline
Rubbing alcohol......
Old 09-20-2018, 05:02 PM
Almostinvincible119's Avatar
Almostinvincible119
Almostinvincible119 is offline
When I raced dirt bikes we would use anything from Superglue, spray paint, hairspray, even locking them on with air pressure (can’t do that with Harley’s as we have holes in our bars). Be creative and get back to us.
Old 09-20-2018, 06:26 PM
Quik's Avatar
Quik
Quik is offline
I bought some two part epoxy, said good for all metals, plastics, rubber, chrome etc. Mixed it up, put a good coat on the bar and put the grip on in the right position, not gonna touch it for 24 hours. If it works...great, if not, I'll sand it off and try something else. Thanks for the input!
Old 09-20-2018, 06:28 PM
Quik's Avatar
Quik
Quik is offline
Oh and I just now realize I posted this in "touring parts" that's my bad, I meant to put it in the touring section.
Old 09-20-2018, 06:35 PM
Kingface's Avatar
Kingface
Kingface is offline
Gorilla Glue. Yes....there will be people saying you will be stuck with the grip on there forever but that is not true. Spread a THIN layer on the handlebar, wet the inside of the grip and slide it on. You have plenty of time to adjust it to the right position as it takes 5 minutes or more to actually set. Once it sets it's on like iron. When changing grips you will have to work it off and pry underneath it but it will come off and the glue easily scrapes off the handlebar. The grip will be ruined though.....but if you're changing grips anyway....who cares?
caleborlando`
General Topics/Tech Tips
04-28-2016 09:49 PM
pomeara
02-01-2014 09:03 AM
EriCal
03-02-2010 02:47 PM
2007fxdc
12-10-2009 09:01 PM
twoseas
11-29-2006 06:34 PM
Quick Reply: Best grip glue
