FS: Touring Suspension Air Pump (54630-03A)
For sale: H-D Touring Suspension Air Pump (54630-03A)
Used only a couple of times. In perfect working condition.
Retails at $49.95.
Sale price: $30 shipped to continental U.S.
PayPal, Square Cash, or Venmo preferred.
This pump was designed to allow safe and simple adjustment of the front and rear air suspension on Touring motorcycles. Unlike a bicycle pump or a fuel station air hose, the hand operated pump with controllable "micro bleed" valve allows precise adjustment to air volume, and the "no loss" air connector maintains shock pressure when the fitting is removed.
The 45" swivel air hose simplifies valve stem attachment
The aluminum housing is compact, lightweight and durable, and fits easily into your bag for "on-the-road" adjustments
The high quality 0-60 psi gauge ensures accurate air pressure
Retails at $49.95.
Mine has zero compression
I got mine with my 2014 FLHTK and used it once and kept it stored in the saddle bag wrapped in my sweatshirt and it has zero compression and will not move any air whatsoever. I replaced the o-rings with new and still nothing. I then tried using motor oil as a thicker lubricant and still no compression. Any ideas?? The one time i did use it, it worked perfectly.
You should really start a new thread for something like this, not resurrect a for sale thread.
