Elf Audio E2125XN class D Amplifier
~~~~~SOLD~~~~~
Hello everyone,
I've had this amp for about 3 years. Sat mostly unused for one of those years. I've had it installed in my Street Glide. It was driving 2 Polk MM651 speakers (2.7 ohms).
The sound was great and I'd be keeping this if it wasn't for the fact that I'm redesigning my audio system and require a 4 channel amp.
Specs are as follows:
E2125XN Two Channel Amp
80 x 2 @ 4 Ohms
125 x 2 @ 2 Ohms
250 x 1 @ 4 Ohms (Bridged)
Double-Sided PCB Board
Selectable Full/Low Pass Crossover Filters
+15dB Variable Bass Boost/li>
Frequency Response: 10Hz - 50kHz
THD: 0.06%
S/N Ratio: >83dB
Separation: >75dB
High Level Inputs
Independent Gain Control (L/R)
8 Gauge Terminals
Dimensions: 7 in x 5.28 in x 2 in
From my understanding, this amp was either identical or similar to the internals of the Arc 125.2 amp.
Also worth noting is that it's a class D amp with NO FM interference.
I'm asking $100 shipped for this.
I have the line level converter that came with it, I'll throw that in as well. I'll also include the 10-Gauge power and ground wire, and the fuse holder I was using. You may want to upgrade to 8-gauge wire, but according to my calculations, 10-gauge was sufficient. I'm also throwing in enough brand new 14ga speaker wire to wire up fairing speakers.
The bottom has a few scratches because I had it mounted to my radio with double sided tape and it got a few scratches scraping the tape off.
The speaker level input converter
Thanks for looking!
Hello everyone,
80 x 2 @ 4 Ohms
125 x 2 @ 2 Ohms
THD: 0.06%
S/N Ratio: >83dB
Separation: >75dB
High Level Inputs
8 Gauge Terminals
Thanks for looking!
The amp is indeed still available.
Technically, it will work with Harley speakers, HOWEVER, I would NOT recommend it because I do not believe they can handle the power of this amp.
I would recommend, if purchasing and installing this amp, finding yourself a set of decent speakers in either 4-ohms or better yet, 2-ohms (there are a lot of suggestions on the forums, however I'd recomend a set of Inifinity Kappa 62.11i, they're about $110 shipped) and I can assure you that you will have a great sounding system at a very reasonable price.
