Ohlins HD 357 Ultimate Shocks for Harley FLH/FLT Touring
These have been Sold!
Only 1160 Miles on these fully adjustable touring shocks. Barely broken in.
See Ohlins site for all specs http://www.ohlinsusa.com/harley-davidson
Would part with them for $895.
See pictures for proof that all hardware and original packaging is all there.
I had them set up by Howard Messner of Motorcyclemetal.com for:
Information about you and your ride
1. How do you know of us?: Chat Site
2. What is the Make of Your Motorcycle?: Harley-Davidson
Year: 2009 Family: Touring Exact Model: FLHTCU
3. Length of Shock Eye to Eye or MM Model Required: Stock 13 "
4. Your weight plus typical every day gear: 215
5. Passenger Weight plus typical every day gear: 160
6. Describe your riding style: 70% 1-Up, 30% 2-Up
7. Do you switch from 2 up to 1 up and add gear: No If Yes, How Much Gear? 0
8. Do you pull a trailer? No
9. Any Additional Features, Requests or Requirements:
215 is my current weight. My gear might be 10 lbs. Its just the Harley tools and pressure gauge and rain gear.
The invoice says....
1.00 HD #6.1 330+10mm/13 1/4" Stroke: 3.562"/90.5
single tube Hose Mount Reservoir,
Rebound, Compression Threaded Body
Adjustable Spring Pre-Load Adj. End eye
Hope that answers the question.
$1250 not including shipping.
No pics. I mounted the reservoir on the horizontal saddle bag rail. Very simple with the hose clamps and rubber mounts. There is clearance. I could access the compression adjustment without removing the saddle bag but it was hard for my big hands so most the time I pulled the pins but left the bags in and tilted them back to get my hands on the ****.
I have seen others mount it under the tourpak but I have an amplifier there.
33mm or a hair under 13 inches. I had to pull the bottom eyelet all the way in to get it on the bike. The bike was on the jack with the back wheel off the ground so it was fully extended. The stock shock I actually had to bring the bike down and compress the backend about 2 mm to get the eyelets to match up. The preload adjustment ends up only about 1-2 threads left to give me the 11mm sag that the spec calls out. Sag being me off the bike vs me on the bike.
