Screamin Eagle "Heavy Breather" Performance Air Cleaner
**SOLD**
This is a like new take off from a 2013 CVO Road Glide Custom. Removed after about 500 miles since it will not fit with the new lower fairings. No rain sock. Reuse your existing backplate gasket. Parts pictured are what is included. No scratches, dings, etc.
Thanks!
Thanks!
This is the link to the HD instruction sheet:
http://www.harley-davidson.com/app-c...ts/-J05499.PDF
I inspected the breather again. You will need a pair of the 11292 O-rings and re-use your existing breather screws and backplate gasket. Should fit fine, but give a call to your local HD service department just to make sure.
Thanks!
Thanks!
FYI, you can buy a short K&N filter that fits with lower fairings if you want to use that intake. I bought one (forget the p/n off the top of my head) on Amazon for about $50). Same short filter from Harley is about $90. Made to use if you have lower fairings. Conical filter with a 70mm flange, 5" base, 4 1/2' length if I remember correctly.
bmna2004
Dyna Parts
05-29-2016 07:08 AM
