Mirage Orange Tour Pak Complete Setup
I bought this Tour Pak a couple of years ago and I have only used it twice. It's time for it to go to a new owner who will enjoy it.
Here's what I've got for sale:
Factory painted Classic Tour Pak in Mirage Orange (79224-09BNR, $749.95)
Harley Davidson Detachable Two-Up Tour Pak Mounting Rack (2009-2013), Powder Coated in Mirage Orange Pearl to match (53276-09A, $194.95)
Harley Davidson Tour Pak Side Marker Light Kit (69494-06, $119.95)
Harley Davidson Chopped Tour Pak Smooth Backrest Pad (52898-98A, $169.95)
Ride Time Technology Multi-Function Light Bar (RTFX-146, $91.95)
Ride Tike Technology Easy Connect Y Wiring Harness (RTQ-2SPI, $47.90)
Saddleman Tour Pak Luggage Bag
The Tour Pak is in like new condition. It's like it just came out of the box from the factory.
The Ride Time Technology Light Bar is currently setup a Brake only and it's super bright and it’s actually a 3-segment light (all red) that can be wired up as run-brake-turn if you like.
The price to purchase today is over $1,375.
Make it yours for $899, shipped to you in the CUS.
Thanks for looking and let me know if you have any questions.
That's the Ride Time Technolgy LED light bar I described in the listing. It's a 3 segment (run-brake-turn), all red unit. I currently have it set up as a brake only and it really pops when you hit the brakes. You can't really even notice it but it gives great braking visibility without ruining the lines of the tour pak.
Thanks for your question.
thanks.
I'm not sure if Kevin with Ride Time Technology is still around but he was great to work with.
I got the LED strip from him. Once again, it's three segment, all red, so you can run it as a run/turn/brake or any combination of that.
Kevin built the harness for the entire Tour Pak. On the connector end, it has a male and female connection for the fender harness under your seat. You just unplug the fender cable from the bike harness. Plug the fender cable into one connector on the Y and the harness connector ot the other connector on the Y and the Tour Pak is on-line.
On the other end of the harness (inside the Tour Pak) it has the leads for run, brake and left and right turn. I used these cool screw together connections that can easily take apart and reconnected. The side LED marker lights are connected to the run leads. The LED is currently wires up as single brake only. You really don't even see if on the unit until you hit the brakes and then it really pops.
I had it set up as turn, run and brake originally but I just felt having the strip go from dark to on with braking was more noticeable that having it be on for run and brighten up for brake.
Bottom line is, you can set it up any way you want.
Good luck with the new unit.
J.D.
J.D.
