starter clicking.....
RE: starter clicking.....
ORIGINAL: ultraultra
I was getting just one click out of mine.. occassionally. It ended up being a loose connection on the + side of the battery. Like the other posts... check connections first.
Outlaw
Well start by cleaning the battery terminals at BOTH ends.
Sometimes the negative gets a little corrosion under the terminal
down on the frame.
Then charge and load test the battery. If weak change it out.
After above if still does it, could be the start relay or just time
to pull the starter, open it and clean and maybe even sand down the
brushes. If worn too far replace them.
down on the frame.
