Road glide turn signal wire routing?
Don't have a pic, but they come off the harness in the center and follow the inner fairing around behind the glove boxes. There is usually a little metal clip that holds the wiring up off the bottom of the fairing to allow the wires to stay out of the way when the outer is re-installed.
Hope that helps.
Zach
Hope that helps.
Zach
Hope that helps.
Zach
Hope that helps.
Zach
Yeah that.... and if you look at the inner fairing between the turn signal holes, you will see a slot. That's where you route the wire in between the inner and outer....... good luck with that
geopac
02-11-2013 04:07 PM
