Swapping out bars on 2015 Road Glide
Old 09-12-2014 | 04:40 PM
Ganooch's Avatar
Ganooch
Default Swapping out bars on 2015 Road Glide
Anyone swap out the bars on their '15 RG? I would want to do some apes, and would imagine with the bars pulled back 5.5" this year there should be some extra wire and cable length. Anyone know how high you can go without replacing the cables or wires?
Old 09-12-2014 | 06:28 PM
ybnorml's Avatar
ybnorml
Not sure if any bars for the RG have hit the market yet....
Old 09-12-2014 | 07:00 PM
Sam2010's Avatar
Sam2010
Harley itself is coming out with three more bar choices for the Road Glide at the beginning of the year I hear. ya want to look at those bars real close they are fat.
Old 09-12-2014 | 08:32 PM
KSGLIDEGUY's Avatar
KSGLIDEGUY
RG Forums has a big thread about this and they say there are pins on the bars where the controls mount preventing rotation of the controls to keep the internal wiring from being damaged. Also there are pins on the riser clamp limiting rotation of the bars. Also they say the bars don't neck down at the clamp.
streetglidedean (02-15-2017)
Old 09-12-2014 | 08:48 PM
themensh's Avatar
themensh
Bike has been out for a week now. Sorry more info is not available.
Old 09-12-2014 | 09:33 PM
lionsm13's Avatar
lionsm13
Do you have 1?
Didn't catch that?
Old 09-13-2014 | 01:50 PM
kojak's Avatar
kojak
Not true. I saw 2 rg that had their stock bars rotated 2 inches higher at Grove's. I talked to the tech and he said its same old knurled, clampdown system.
Old 09-17-2014 | 12:31 PM
breto's Avatar
breto
Stage IV
Default Has anyone actually rotated the Bars
Would like to rotate the bars up to see if it makes the position a little better, i see someone here mentioned they had seen a couple of bikes that had this done, has anyone done this? Would like to know what all it takes? Anyone know if the igntion switch comes off the same as previous versions did?
Old 09-17-2014 | 02:53 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I have read that you can just pull the pins out and run them without the pins thus a regular bars should work but there will not be anti rotation pins for the controls or risers. This is new for this year so none of my Harley's have ever come with this feature and I have not had an issue without pins. This reminds me of Japanese bikes with the switch housings.
It might hard to rotate the angle of the switch housings with the pins in them. Here is a link to the other forum.
http://www.roadglide.org/showthread.php?t=171794&page=4
Old 09-17-2014 | 05:27 PM
SDVmnt's Avatar
SDVmnt
I was also "Told" by a salesmen that the black "clamps" so to speak. The part that faces the rider on each side, are actually larger to provide extra dampening. Weighted I guess you'd say.
Made to eliminate some sort of vibration they found on the road glides.
Take it for what it's worth but it sounded plausible to me. They're definitely 4x larger than the street glide's rear clamps.
