Pulled the trigger on an 98"....
Pulled the trigger on a 98"....
I scheduled a 98" FM build with TW-555-6R cams in 4 weeks. Should keep me entertained for a bit. Had the compensator nut back out at 12K miles so I feel with my luck the cam chain tensioner's should fail soon. Now with the motor build including the tensioner's I shouldn't worry about that anymore as long as I can make it to the build date.
Anything else to address?
I'll be following the build. I am getting ready to call FM and order the same. Trying to decide if I should go with the TW-555 cam or not. I have an 02, so I would need to upgrade the valve springs. I think a buddy has a set of SE prings that can take the lift. I can't spring for the B heads right now. Good luck and enjoy!!
Neil
RDMC
Neil
RDMC
Thanks for the direction to the post.
Link for future info:
https://www.hdforums.com/forum/touri...e-testing.html
Karsten
Exhaust System Topics
22
06-12-2010 02:02 PM
