what all is need with a color matched tour pak
Old 09-07-2014 | 09:08 PM
liquidr1's Avatar
liquidr1
Default what all is need with a color matched tour pak
Looking at buying a Harley color matched tour pak for my 13 RGC. I know I need the mount, pad, and the tour pak itself. I have heard its extra to have the lock keyed to match the bike. Anything else im missing?
Old 09-07-2014 | 09:20 PM
CSMHOG's Avatar
CSMHOG
You might want to think about your antena. Do you plan to add brake lights also? You're correct about having the tour pak rekeyed if you want one key for everything.
Old 09-07-2014 | 09:44 PM
RollaMo's Avatar
RollaMo
The "easiest" way would be to visit your local dealer and go over the options you want.
Items you will need
4-Point docking kit
Tour Pack mounting base - 2 versions available, either solo or 2-up - pick the style you want
Tour Pack itself (King, Chopped, Razor)
Tour Pack backrest (many styles available)
Lock Set - Dealer can order keyed to your current key (they just need the key number)
If you don't want to use your local dealer, you can order all the parts through one of the online dealers.
Old 09-08-2014 | 04:11 AM
Rustrtal's Avatar
Rustrtal
I recommend springing for the liner too
Old 09-08-2014 | 06:12 AM
Campy Roadie's Avatar
Campy Roadie
Veteran: Marine Corp
A pile of money.
Old 09-08-2014 | 09:23 AM
austinslider's Avatar
austinslider
This was one of the reasons that I sprung for an ultra in the first place...tour pak and lower fairings.
Old 09-08-2014 | 10:03 AM
liquidr1's Avatar
liquidr1
Does the tour pak come with hinges and latches or do i have to get those seprately.
Old 09-08-2014 | 10:52 AM
RollaMo's Avatar
RollaMo
Yes, hinges and latches are pre-installed.
However, I think most would recommend upgrading to premium hinges.
I did that on mine, and they are much better.
Old 09-08-2014 | 09:14 PM
liquidr1's Avatar
liquidr1
do you have the part number for those. I didn't know there was premium hinges. I thought they were all the same. Whats the difference.
Old 09-09-2014 | 06:33 AM
RollaMo's Avatar
RollaMo
The stock hinges work, but they just look "cheap" compared to the premium hinges.
The premium hinges are what come stock on the CVO bikes.
Premium hinge part numbers:
Chrome 79211-08A
Black 53000131
You see the difference in these two pictures.
Attached Thumbnails what all is need with a color matched tour pak-stock-hinge.jpg   what all is need with a color matched tour pak-premium-hinge.jpg
Quick Reply: what all is need with a color matched tour pak
