what all is need with a color matched tour pak
Old 09-10-2014 | 12:01 AM
nevada72's Avatar
nevada72
If you buy the Rushmore stuff it's pre drilled. In fact, the tourpack uses studs and the holes are in the rack only.
Old 09-10-2014 | 06:32 AM
RollaMo's Avatar
RollaMo
Originally Posted by liquidr1
Are the holes already drilled in the tour pak for the mount? or do I have to do that also?
Originally Posted by gonenomad
You get to drill the holes. The bolt pattern changed over the years.
My chopped tour pack came pre-drilled for the standard backrest.
If you want to put on the King style wrap-around backrest on a chopped tour pack, you'll have to drill some holes.
But the tour packs come with the holes needed for the style of backrest that is standard with that tour pack.
Old 09-10-2014 | 06:43 AM
liquidr1's Avatar
liquidr1
I was refering to the holes to mount it to the rack. Not the back rest pad
Old 09-10-2014 | 10:12 AM
RollaMo's Avatar
RollaMo
Oh, I misunderstood then.
Yes, you will have to drill those holes. And there is a template included with the rack.
Old 09-13-2014 | 01:52 PM
liquidr1's Avatar
liquidr1
does the tour pak come with the inside support plate and hardware?
Old 09-13-2014 | 05:33 PM
ultraclassic53's Avatar
ultraclassic53
I've done a couple of these. It's pretty simple. The ones I've done had pre drilled holes and yes there is a metal plate on the bottom of the tour pack
Old 09-13-2014 | 05:37 PM
ultraclassic53
Actually I just did one on a 13 a few weeks ago . I put a king tour pack on my cvo custom road glide.
Old 09-13-2014 | 06:39 PM
rrinsp's Avatar
rrinsp
I looked on craigslist,went to swap meets, then found one on ebay for $600. delivered. I got lucky it was color matched to my bike (black pearl). It came with the backrest and 2 up docking hardware. All I had to do was buy the 4 point docking hardware for the bike. My point is look around you might find a deal.. good luck
Old 09-13-2014 | 06:55 PM
RollaMo's Avatar
RollaMo
Yes.
All you need to purchase is what I listed in post #3.
Old 09-13-2014 | 07:22 PM
liquidr1's Avatar
liquidr1
where the holes already pre-drilled?
hammer136
04-16-2020 12:51 AM
hammer136
05-05-2019 10:14 AM
liquidr1
12-24-2014 11:11 AM
john62
08-06-2009 01:32 PM
shortleg
01-03-2008 11:00 PM
Quick Reply: what all is need with a color matched tour pak
