Breather for 2007 Road king
Old 09-07-2014 | 03:18 PM
propwash1970's Avatar
propwash1970
Default Breather for 2007 Road king
Will part# 29253-08B Screamin' Eagle Heavy Breather Performance Air Cleaner Kit, fit my 2007 RK? I know the HD site says its for a 08 and up. I see several 07's with a SE heavy AC but I am unsure of the part#! Did a search but nothing specific. Just curious.
Old 09-07-2014 | 03:39 PM
mkguitar's Avatar
mkguitar
the 08 means the part was introduced in 2008.
this usually means that parts do not retrofit, but sometimes they do.
i would like to send you down a rat-hole...if you go to ronnies online partsfinder, you can select various years and models and compare the parts used ( by number) and that'll help determine fit:
http://www.shopronniesharleydavidson...partfinder.htm
click on OEM
then motorcycle
year, model, assembly
compare the 07 throttle body to 08 and you'll see that 08 introduced a larger TB...
there is a heavy breather for the 07...but in terms of performance there is nothing added over any of the many hiflow intakes- it's a looks thing.
I always suggest the ness big sucker- usually under $130 on ebay from easternpc- forum member DK Customs may price match with the ship- ask them
mike
Old 09-07-2014 | 04:00 PM
OxJaw's Avatar
OxJaw
You need the one for the Dyna/Softail models. In 08 Harley went with a bigger throttle body on the touring bikes. The TB on the 08 up Dyna/Softail is the same as the earlier FI Touring bikes from what I could find.
https://www.hdforums.com/forum/softa...ater-only.html
https://www.hdforums.com/forum/softa...fferences.html
Old 09-07-2014 | 04:58 PM
propwash1970
Thanks mkguitar & oxjaw! I'll check out what both of you suggested. I have the Arlen ness big sucker but was wanting a different look!
dcrich19
09-01-2012 05:43 AM
brymer84
07-21-2010 06:12 PM
Bobber Jay
02-07-2009 07:12 AM
ponesma
12-12-2007 10:01 AM
Quick Reply: Breather for 2007 Road king
