Does your air shocks pressure slowly leak down?
Old 09-07-2014, 02:30 PM
liquidr1's Avatar
liquidr1
liquidr1 is offline
Default Does your air shocks pressure slowly leak down?
Hey everyone, My air shocks will leak down 20-25 psi over the course of 4-5 days just sitting in the garage. Its a 2013 RGC. My buddy says his 2013 street glide shocks hold the pressure just fine. Just wondering if I should turn it in on warranty or is it a normal thing to have to re-pressurize them so often.
Old 09-07-2014, 02:37 PM
dontdropit's Avatar
dontdropit
dontdropit is offline
Some of them will leak at the fittings. Put air in them and spray some soapy water on the fittings and look for the leak. It will usually show itself with bubbles. If you have a leak at a fitting just remove the line trim a little off and reattach it, that usually will fix it
Old 09-07-2014, 02:41 PM
Markymannn's Avatar
Markymannn
Markymannn is offline
My 2004 leaks down about 2# a month. You got a leak somewhere
Old 09-07-2014, 02:49 PM
Rockrivr1's Avatar
Rockrivr1
Rockrivr1 is offline
Have the same problem with my 14 Limited. Brought it in for service and they said nothing was wrong, but there is still a slow leak. I'll try the soap and water to see if there are any bubbles.
Old 09-07-2014, 02:51 PM
fireman9170's Avatar
fireman9170
fireman9170 is offline
use soapy water, that’ll tell ya
Old 09-07-2014, 02:53 PM
TKDKurt's Avatar
TKDKurt
TKDKurt is offline
Same with my 2011. Very little leakage over time. Check it out.
Old 09-07-2014, 02:58 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Mine leak down. I asked the exact same question as you when I first bought the bike. Not a ton, but over a weeks time the bike will loose a noticeable amount of air. I have heard so many varying responses, that I just gave up. Because I change them with such regularity....... like every time the wife gets on, or I ride solo, that I just whip out the pump and pump them to where I want them. How much air loss over time is normal, I have no idea, but for me, SOME air loss over a weeks time seems to be normal.
Old 09-07-2014, 03:37 PM
RHillbilly's Avatar
RHillbilly
RHillbilly is offline
My 2011 leaked tried everything couldn't find the leak put a set of progressives on no more problems and a much better ride
Old 09-07-2014, 04:25 PM
Weavr99FLHT's Avatar
Weavr99FLHT
Weavr99FLHT is offline
mine lose about 2 # per month. lost 8# over the winter.
Old 09-07-2014, 05:23 PM
bigfish_Oh's Avatar
bigfish_Oh
bigfish_Oh is offline
mine always leaked, dealer blew it off. I put on progressives. I put the air shocks on my nightster with a bar mounted pressure guage and fill fitting. Filled them to 42# and never lost an oz., that's with me at at 260 and wife at 160 and watching the needle bounce past 60 constantly. (it's been over 2 months)
If the lines are assembled correctly they will not leak
Quick Reply: Does your air shocks pressure slowly leak down?
