Interesting discovery on 1st gear clunk
I have discovered something regarding the infamous clunk going into first gear. I found that if I back my bike out of the garage with the engine running and still in neutral, but with the clutch pulled in and then go into 1st gear, it just slides in and makes no noise at all.
Backing out of the garage is about 20 feet or so to the street. I have tested it over and over, and it works every time.
Just thought I'd share. I figure it has to be better on the bits inside the tranny etc. in the long run to not have that loud assed clunk.
What's happening is you're allowing the engine and transmission to pre-lube the moving, rotating parts of the clutch. Try this, turn your bike around in the garage before starting it, then start it, wait about 10 seconds or so,pull the clutch lever in , give it a couple quick 2 or 3 blips on the throttle and then shift it into gear. No clunk.
This makes all the sense in the world. Starting the bike in neutral, the trans mainshaft is still turning at engine rpm. Due to the stiction in the clutch plates, the clutch doesn't completely disengage. When you move the bike, the countershaft is moved, you're more likely to overcome the stiction in with the clutch plates and the shift to 1rst is smooth.
Received 2,529 Likes
Ever happen to you?
System is prelubed, I would say...
That theory is BS.
OP Theory has merit, is interesting, thanks for posting.
Man, at the BS we see in here on any given day...
