Pulstar Spark plugs
Old 09-04-2014, 06:21 PM
pcwizard's Avatar
pcwizard
pcwizard is offline
Default Pulstar Spark plugs
Any feedback on these?
Old 09-04-2014, 06:27 PM
RollaMo's Avatar
RollaMo
RollaMo is offline
Snake Oil
All any spark plug needs to do is "spark".
A stock plug does that just fine, and you will not notice any difference in performance using any of those "gimmick" plugs.
Old 09-04-2014, 06:49 PM
bigheadted's Avatar
bigheadted
bigheadted is offline
I bought the snake oil and have been happy with them. I noticed a quicker start up and a slight increase in MPG plus it seemed to run crisper. I ran them for 5 tanks of fuel and monitored the results then switched back to stock plugs, ran them 5 tanks and switched back to the pulstars.
Funny with the line of thinking all you need is a spark mentality. If that were the case we would still have points.
Back when electronic ignitions and MSD boxes were new on the scene the dinosaurs all said it was snake oil, same with the Unilite distributors. Same with fuel injection too. I smoked all their asses in my GTO regularly.
If everyone thought snake oil for everything new we would all be Fred Flinstoning around with our feet.
I recall some folks tried them and sent them back and others had good results, they have a unconditional warranty so it is no risk to try yourself.
Same crap talked about the Boyeson X-wing, I "suckered " for that too.
Funny thing is riding buddies with very similar stock bikes but much smaller men as I am 290 and they are lucky to see 180 so I have a weight disadvantage, but they would always barely walk away from me but after adding the plugs and wing I was able to barely walk from them. Nothing real dramatic but a percent here and there makes a difference.
Think for yourself and try them, you might be happy.
Old 09-04-2014, 06:54 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
Pure crap!
Old 09-04-2014, 07:00 PM
Gliden's Avatar
Gliden
Gliden is offline
Didn't we used to buy hotter coils back in the day?
That was all bs too.
Old 09-04-2014, 07:29 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
Yep, these High performance Products have been around for years, do They work? The simple Answer is NO! These People just want Your $$$$$$$$$$$$$$. When Their Product doesn't work, They will tell You that You have another problem, and try to sell You something else. Been there and done that, like a fool.
Old 09-04-2014, 08:10 PM
mikeo33y's Avatar
mikeo33y
mikeo33y is offline
im in agreement. the snake oil guys still have black and white TV,s and prob have land lines. Ive tried boyesen products and they usually work. the stuff dosent turn your big into a rocket ship but can help with crisp throttle response. Eveeen Boyesen was an incredible engineer by trade. But hey. The snake oil guys prob think carbs are better than throttle bodies and transistor radios are superior to my smartphone. Ill try anything reasonable.
Old 09-04-2014, 08:23 PM
JD HD's Avatar
JD HD
JD HD is offline
NRHS tested them on the dyno a while back and found absolutely no gain with them. There was a long running thread on them a year or two ago.
Old 09-04-2014, 08:46 PM
btsom's Avatar
btsom
btsom is offline
Your coil only puts out so much, that is what any plug has to work with. If these plugs have a gadget that saves up the juice for one big, very short duration spark, that would seem to slightly retard the timing. Were they engineered to work with the Ion Knock system? Too many unknowns involved, but if you like them, great. Any new plug will out perform the same plug that has 20,000 miles on it. That may be part of what you are seeing.
Old 09-05-2014, 04:30 AM
pcwizard's Avatar
pcwizard
pcwizard is offline
Thanks all. Appreciate it. :-)
Quick Reply: Pulstar Spark plugs
