Primary oil additives
09-03-2014, 08:33 AM
Whats your opinions on adding additives to the primary ala energy release products
09-03-2014, 08:57 AM
What benefit do you expect to gain by adding something in addition to the oil in your primary? Why not just run a good quality lubricant and save your money by not buying an additive?
09-03-2014, 08:58 AM
If your primary fluid doesn't come with the additives already in it I wouldn't be adding any same for the trans/engine.
09-03-2014, 09:03 AM
I use formula+ in it but was just curious and I'm not a wrench
09-03-2014, 09:04 AM
09-03-2014, 09:10 AM
All oils we buy have additives, so I can see no benefit in adding yet more. There is enough about oils on HDF to satisfy most of us, so read up a little, if you feel the need to, and buy an oil that other's recommend.
09-03-2014, 09:11 AM
Main purpose for the oil in the primary is to lube the chain and cool the clutch plates. Special additives are not needed to accomplish the task.
09-03-2014, 09:49 AM
The basic claim is a reduction in friction. Not necessarily something you want up on your clutch plates.
09-03-2014, 10:00 AM
09-03-2014, 10:03 AM
Ok thanks for the input guys
blackflame
06-04-2014 09:42 PM
electra glide
02-06-2011 07:30 AM
tomtek
10-19-2010 06:36 PM
hogblue
Oil Archive (no new posts)
03-08-2010 04:12 PM
tencrore
05-24-2009 02:32 PM
