Notices
Woodgrain dash kit??
Old 04-10-2007, 01:15 AM
Gunney8's Avatar
Gunney8
Gunney8 is offline
Default RE: Woodgrain dash kit??
OK, how about a carbon fiber inner?
Old 04-10-2007, 01:38 AM
vegashd's Avatar
vegashd
vegashd is offline
ORIGINAL: jefkat2
This web site is where you need to go. Had work done for my Jeep by them.
http://www.phoenix-image.com/HydroGraphics.htm
2007 FLHTC
I dug up this link and forgot to update it. I did my Harley truck and my F250 with these guys. Took my leather wrapped wheel and put plastic type inserts on top and bottom like my lexus. It owuld not wear like th leather. They did all the interior on both the isted trucks and did AWESOME
Old 04-10-2007, 10:27 AM
LOU's Avatar
LOU
LOU is offline
I would go with a carbon fiber inner fairing in a heartbeat. In fact I placed an inner fairing wanted ad in the classifieds to see if I could make that happen.
Old 04-10-2007, 11:00 AM
wjl24's Avatar
wjl24
wjl24 is offline
Old 04-10-2007, 11:16 AM
Danbousmc's Avatar
Danbousmc
Danbousmc is offline
http://www.jpcycles.com/catalog/2007...alog/0418.html
J&P Cycles has one for the FLHT.
Old 04-10-2007, 01:04 PM
chiabate's Avatar
chiabate
chiabate is offline
They're not the same fairing. If you don't find one, you might have to make one if you're handy enough. Around here there's a place called Owl Lumber, years ago I had an Alfa that had speaker holes cut into the kickplates on the doors instead of under the dash where they belonged. I bought Mahogany veneer to match the steering wheel and cut to fit. Sanded, sanded, sanded then sprayed with spar varnish (marine). Contact cement after roughing the plastic and clamped at the curves. Never came off. Dash guys who sub at car dealerships use contact cement in addition to the adhesive on the kits, heat guns get real hot, use a blow dryer instead. Veneers are thin enough to cut with a razor knife/exacto blade. I'll be capping a beam at the house with red oak veneer I just bought from them this spring, it's not really that hard.
IndyNick
Audio Systems
12-31-2019 06:26 AM
Buelligan666
Audio Systems
05-26-2017 12:57 AM
berndog
Shovelhead
06-09-2012 06:00 PM
Hammer107
Touring Parts
06-25-2010 10:25 AM
Terminator69
02-02-2010 02:33 PM
Quick Reply: Woodgrain dash kit??
