RK Handlebar help
RK Handlebar help
Been looking thru the forum for handlebar suggestions and still need some help...I have a 2010 RK with stock bars that are killing me in the elbows(near locked) and shoulders... I have to lean forward and and have too much weight on my hands...I'm short 5'6" and have a short reach (24" from armpit to knuckles)
Is there anyone out there about my size that replaced bars w good results? Want to keep existing cables and lines and do not want to extend any of those...not interested in 18" ape hangers...
I think I need something with about 12" pullback and 7" rise and 30" width
Have read up on the HD Heritage bars and HD High bars...anyone out there use Khome Werks Heritage Style Stretch 300043 or the 300042? Any other suggestions that won't break the piggy bank?
We're roughly the same size, although my bike isn't an RK. Have you simply tried adjusting your bars towards you? Costs nothing more than a little time. I too had to reach for my bars and was suffering from stiff shoulders after a while, however a few attempts at changing the position of the stock bars worked wonders! Try it before spending any money. I've done trips over 2,500 miles in complete comfort.
I also have a 2010 RKC.Had the same problems so I switched the stock bars for What is known as "Heritage style bars".That took care of all my problems. With those you can keep your cable and wires without needing to lengthen them.Any higher and you will have to.
If I'm not mistaken,in 2011 or 2012 the RKC came stock with the "Heritage style bars".
Received 1,643 Likes
Go here: http://www.wild1inc.com/ Check out the section "Handlebars 101". I have 518's on my RK. Absolutely perfect, but I also use a backrest, which I believe is absolutely essential. You might like the 508's, and again, a backrest is almost required when riding for long periods of time.
respects,
ed
respects,
ed
