Jesus! What is the torque spec for primary derby cover?
Old 08-27-2014, 06:28 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,072 Likes on 2,507 Posts
Originally Posted by p51bombay
A stock DC has one rubber gasket.
There's also a flat cardboard one for derby covers with no gasket groove. It's an either or thing, just one gasket.
  #32
Old 08-27-2014, 06:50 AM
ynots's Avatar
ynots
ynots is offline
Originally Posted by Henry89
Thanks. So the LHS sold me the large rubber o-ring derby cover gasket and the large clutch inspection cover gasket, part number 25416-99C. I'm using the stock derby cover so I can use the large rubber 0-ring gasket or the clutch inspection cover gasket, part number 25416-99C? Thanks!
the derby gaskets dont need to be replaced each time you change the oil or do a clutch adjustment
  #33
Old 08-27-2014, 08:10 AM
Henry89's Avatar
Henry89
Henry89 is offline
10-4. Thanks for the feedback!
  #34
Old 08-27-2014, 09:39 AM
Bill03E's Avatar
Bill03E
Bill03E is offline
If I get a tight one, I use a big soldering iron to heat the bolts, and they come right out.
  #35
Old 08-27-2014, 09:42 AM
qtrracer's Avatar
qtrracer
qtrracer is offline
Use a screwdriver bit/socket holder to tighten derby cover bolts. Done.
  #36
Old 08-27-2014, 10:52 AM
dochawken's Avatar
dochawken
dochawken is offline
Indeed...I like that the best.
Signed: Jesus
  #37
Old 08-27-2014, 10:57 AM
airfuel's Avatar
airfuel
airfuel is offline
I only use torque wrenches on critical parts like brake calipers, axles, space shuttle engines etc!
On a motorcycle, I mostly use a stubby ratchet wrench...... stops gorilla over tightening of fasteners. Full size ratchets for big stuff and loosening only.
  #38
Old 08-27-2014, 11:49 AM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Originally Posted by Fishrrman
SafetyMan wrote above:
...Never, never, NEVER use a torque wrench on the derby cover bolts.
Don't even use a standard ratchet wrench.
I prefer allen heads to Torx -- much better...
That's the most illogical advice I've ever read. Why in the world would you advise any one to NOT use a torque wrench? I have 60,000 miles on this bike and many more on other bikes and have never damaged a derby cover screw. I torque them to 100 in. Lbs with no anti-seize or loctite and they come out with no problem every time. There is nothing wrong with Torx if used correctly and with the correct bit.
  #39
Old 08-27-2014, 12:05 PM
roadking2014's Avatar
roadking2014
roadking2014 is offline
I know thats right.
I need a torque wrench cause I will overtighten everything.
  #40
Old 08-27-2014, 05:54 PM
Leftcoaster's Avatar
Leftcoaster
Leftcoaster is offline
The clutch cover and the derby cover are one in the same. I use the paper gasket with the silicone seal.
I've never used a torque wrench on derby cover screws - it just isn't necessary. Tighten them just past snug with whatever your favorite tool is....maybe a dab of anti-seize but NO Loctite.
Quick Reply: Jesus! What is the torque spec for primary derby cover?
