Jesus! What is the torque spec for primary derby cover?
Old 08-24-2014, 08:37 PM
steelerdude1's Avatar
steelerdude1
steelerdude1 is offline
Originally Posted by Ron750
84-108 in-lbs (INCH POUNDS].Not foot-lbs.
There is your correct answer, I usually go in the middle at 100 inch pounds. They aren't supposed to be super tight.
Old 08-24-2014, 08:40 PM
hAkron's Avatar
hAkron
hAkron is offline
Originally Posted by sbeast
when i did the oil on my friends dyna, all the dirby bolts were torqued on to an absurd extent. i had to use a socket wrench to break em loose
I tried with one of those Swiss Army knife style ones (it's stubby with a big plastic handle)
Like this
Then with a breaker bar and T-27 socket when that didn't work.
Crummy soft bolts tightened too much make for an exciting afternoon.
Old 08-24-2014, 08:44 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
You don't need bolt extractors.
The heads are easy to drill off, then remove the cover, then take vice grips to the remaining stud. Use a bit just a tad bigger than the stud.
It is truly a 2 minute simple job.
Been there done that.
The problem is a galvanic reaction between the iron on the bolt and the aluminum on the primary.
They fixed that in more recent years by adding an insert.
Moving forward, I would HIGHLY suggest adding anti-seize to your bolts.
Old 08-24-2014, 09:46 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,529 Likes on 1,424 Posts
I also anti seize mine, and just one hand snug is fine. I have removed ones that pop like hell where some idiot moron went way too tight on them. No excuse for it.
On cars and trucks, morons been over doing lug nuts, drain plugs, oil filters, and valve cover bolts since they first rolled off the line.
I remember a sign: "Nothing can be completely foolproof, because fools can be incredibly clever".
Old 08-24-2014, 11:03 PM
Fishrrman's Avatar
Fishrrman
Fishrrman is offline
SafetyMan wrote above:
[[ Moving forward, I would HIGHLY suggest adding anti-seize to your bolts. ]]
That's the way, but I would like to add this:
Never, never, NEVER use a torque wrench on the derby cover bolts.
Don't even use a standard ratchet wrench.
I prefer allen heads to Torx -- much better.
Thread them in by hand, then use either a handheld allen wrench or a "palm ratchet" (Sears used to sell these, not sure who sells them now).
Tighten them "snug", then just a little more.
That'll do it....
Old 08-24-2014, 11:15 PM
ynots's Avatar
ynots
ynots is offline
I agree, I do have torque wrenches but never bother to use them on a derby cover. If youve done enough wrenching and have a little common sense you shouldnt need one to tighten small fasteners
Old 08-24-2014, 11:29 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
I had a spare primary cover I was getting powder coated, went to remove the derby cover and I've never seen such tight or strong screws. Several of them were so tight that even with a snap-on T-27 on a hand impact - the screws stayed put, didn't strip out and twisted the splines on the T-27. At that point I quit and drilled the head off of them - once the torque was released you could unscrew them with your fingers. Says to me these are very high quality screws and that some idiot must have used a 1/2" impact to tighten them.
Old 08-25-2014, 01:51 AM
dickey's Avatar
dickey
dickey is offline
Received 5,651 Likes on 2,536 Posts
Taketh not the Lord's name in vain.
Old 08-25-2014, 03:36 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,072 Likes on 2,507 Posts
Those derby cover screws weren't on too tight. It's dissimilar metals, steel screws into aluminum. As mentioned, a little anti-sieze will keep this from happening again. 100 inch pounds and use the proper sequence.
Old 08-25-2014, 05:55 AM
skratch's Avatar
skratch
skratch is offline
Received 4,357 Likes on 2,536 Posts
how do you know his hispanic gardener doesn't work on harleys on the side?
Quick Reply: Jesus! What is the torque spec for primary derby cover?
