2013 ultra classic
Old 08-21-2014 | 06:42 AM
scrapper's Avatar
scrapper
Question 2013 ultra classic
Will the headlight assembly and blinkers fit my 2011 Road king?
Old 08-21-2014 | 07:19 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Your question didn't belong in the "New Members Area".
It's for introductions. So it was moved in one of the other forums.
Old 08-21-2014 | 11:15 AM
mkguitar's Avatar
mkguitar
yes, the 7" headlight will fit from 2014 back to 1949...I have a 2009 headlight in my 1953- with a 6 volt bulb.
your swap will be pretty simple.
alot of HD parts interchange years and models, many of us use a parts manual to track changes and "what fits what"...the last 2 digits of most HD parts numbers indicate the year the part was introduced.
a B, C, D etc means the part has been revised- this doesn't affect fitment.
multiple letters like "CLY" may be a color code for painted parts
an online parts manual is here:
http://www.shopronniesharleydavidson...partfinder.htm
scroll down and click on motorcycle
then select year
and model
then the assembly you are interested in- these are exploded diagrams so really handy if you are fixin' on something
in your case the headlight reflector on the Ultra is a "2005" part. the spot bracket is a 1996 part- i think...
you can go back and forth between 2 models to see which use the same part
Mike
paullavery
12-28-2016 03:51 AM
72fl
Touring Parts
05-03-2015 10:07 AM
moerule s
EVO
03-22-2015 03:22 PM
Dutch101st
02-28-2015 11:40 PM
Trunk Monkey
11-19-2012 12:58 PM
Quick Reply: 2013 ultra classic
