Rear Brake Pads Causing Noise
My 2014 Limited has a rattle/clunk whenever I hit a bump. I narrowed it down to the rear brake pads causing the rattle/clunk. With the saddlebag off, bike on lift, I can hit the rear tire with a rubber mallet and cause the noise. If I hold the rear brake pedal or hold the 2 brake pads with my fingers, then hit the tire, the noise stops. The 2 pads seem kind of loose. Bike has done this since new. Anti rattle spring is in place. Rotor is straight.
What can I use to stop the noise? I thought of brake pad silencer but I thought that stuff was for squealing brakes.
YPD485
08-18-2014 11:42 PM
