Can the 2015 Road Glide Fairing bet retrofitted to 2013 and earlier?
Old 02-16-2020 | 08:56 PM
ExtremeBaggers's Avatar
ExtremeBaggers
Originally Posted by PIGASUS1
Greetings, I ran into a guy on another page named Justin Von Metal. He will get you an entire front end, triple clamps, tubes legs, cow bells, and he valves it for about $2k. Your front end would bring $500 for someone doing a resto. Powdercoated in your choice of colors. You get the 49mm tubes, you get the top triple clamp, and you get custom valving for you. Huge upgrade over the 50 year old front ends they used through 2013. Mine went on a 2004 and 2007 so I had to change out wheel bearings for 25mm. Respect, Wes
How sir did you get trees to fit a different neck. It’s not doable
  #32
Old 02-16-2020 | 09:10 PM
skratch's Avatar
skratch
Originally Posted by ExtremeBaggers
you post this on everyone’s fairing swap thread.
should his answer be different for every time that question gets asked?
  #33
Old 02-16-2020 | 11:38 PM
glcash's Avatar
glcash
It can be done
Gibdog000 (03-18-2021)
  #34
Old 05-17-2020 | 05:47 PM
Eric Parker's Avatar
Eric Parker
Stage I
Default Year
What year bike? I’m looking to do it this next winter!!!
  #35
Old 07-27-2020 | 08:38 PM
Gbawuru's Avatar
Gbawuru
Stage II
Default Need to set up my 2013 road glide FLTRU
Hi can I get the info for the company that did this setup please. Thanks
  #36
Old 07-27-2020 | 11:01 PM
ExtremeBaggers
Big Bear Choppers BBC he’s doing high performance baggers now. He makes a stem that goes into the 49mm trees to install on a 2013- https://bigbearperformance.com/produ...em-conversion/
Gbawuru (07-27-2020)
  #37
Old 07-27-2020 | 11:17 PM
Gbawuru's Avatar
Gbawuru
Stage II
Default Thanks
Thanks sir . He is 30 min from me . Thanks again
  #38
Old 03-18-2021 | 10:57 PM
Gibdog000's Avatar
Gibdog000
Stage I
Do you have a list of what brackets were used to make this possible? Also, what did you do for gauge wiring and or gauges?
  #39
Old 12-12-2021 | 10:56 AM
Xpcgamer's Avatar
Xpcgamer
6th Gear
I installed a Pre Rushmore inner and outer on my Road King. After I did the install I wondered if I should have just used the Rushmore one. I was not worried about the electronics. I wired a stereo, amp and speakers. Used an electronic Volt Meter gauge and a stock oil pressure gauge (need to purchase a Electra Glide sending unit to wire in the Road King idiot light and the new pressure gauge) and plug the other two holes with tweeters. I purchased the brackets to eliminate the Engine guard mounts. I used blank cover plates for the 4 wire turn signals( Road King are 3 wire) and I used Led strips for running lights and front turn signals. I have less than 1k into it and I don't have a monthly note on my bike so selling it to buy a RG was not an option.
oleksa (08-24-2024)
  #40
Old 09-27-2024 | 01:04 AM
KenJac's Avatar
KenJac
5th Gear
Originally Posted by scottt
That is correct. The neck is completely different, the motor mounts were moved slightly as well. The 14 up bike is changed more than you would think.
the frames are not completely different. There are changes but but there some cross over . I have a 2012 street glide. And doing a conversion to road glide . .i am going with a 2015 fairing. Why because can get one in carbon fiber. No one make on for a 2012. . I won't have a entertainment system so no problem there and the only Guages really needed is speedometer and tachometer. And warning lights. . And for the ones that ask that question, why don't byou buy a 2015 RG . Well that still won't help what i want to do. I still be put money into it and changing baprts as with the other. .
SmittyFXDL
11-10-2020 11:16 AM
Lu
06-11-2017 04:20 PM
gilbos440rt
09-28-2012 09:59 PM
BigDaveOnBass
11-12-2008 07:36 AM
americanthunder
11-11-2008 10:25 PM
Quick Reply: Can the 2015 Road Glide Fairing bet retrofitted to 2013 and earlier?
