Can the 2015 Road Glide Fairing bet retrofitted to 2013 and earlier?
Old 08-16-2014 | 11:13 AM
scottt's Avatar
scottt
Originally Posted by safetyman
negative ghost riders...
The red indicates the 2014 changes to the frame. I'm not saying the changes will affect whether or not a '15 catfish-nose will fit.
....but it is not, in fact, the same.
bingo
Old 08-16-2014 | 11:27 AM
davessworks's Avatar
davessworks
Originally Posted by Keithhu
At a minimum, you'd have to figure out what to do with that big hole where the audio/nav display goes. You cant buy that for your bike because its designed for the CAN BUS/HD Lan architecture which your bike is not wired for, and at a minimum would require a complete rewiring of the bike.
Not to mention the gauges.
With regard to the frame, enough's already been said to indicate the degree of changes. The part number is also (naturally) different indicating further that it is not the same part (47900-14BHP).
Old 08-16-2014 | 11:44 AM
SeaZund's Avatar
SeaZund
Originally Posted by scottt
Can you imagine trying to sell or trade a 13 Roadglide with a 15 fairing.
If there's somebody willing to build it; there's bound to be somebody willing to buy it
Hollywood Rides (05-14-2023)
Old 04-19-2017 | 06:05 PM
PIGASUS1's Avatar
PIGASUS1
Greetings, I ran into a guy on another page named Justin Von Metal. He will get you an entire front end, triple clamps, tubes legs, cow bells, and he valves it for about $2k. Your front end would bring $500 for someone doing a resto. Powdercoated in your choice of colors. You get the 49mm tubes, you get the top triple clamp, and you get custom valving for you. Huge upgrade over the 50 year old front ends they used through 2013. Mine went on a 2004 and 2007 so I had to change out wheel bearings for 25mm. Respect, Wes
Old 04-19-2017 | 07:49 PM
groupw's Avatar
groupw
Originally Posted by nevada72
Short answer - you would probably spend less money by selling your bike and buying a new road glide.
Old 07-27-2019 | 08:03 PM
Brian Michalak's Avatar
Brian Michalak
Stage I
They make Radio's that will fit and hook up to your bike
Old 02-16-2020 | 08:29 PM
ExtremeBaggers's Avatar
ExtremeBaggers
you fit any double din radio to it.
Old 02-16-2020 | 08:30 PM
ExtremeBaggers
Short answer - yes. Anything is possible.
Right answer - yes, but you would probably spend less money by selling your bike and buying a new road glide. Less headaches anyway.
Not if you sell your old parts and Headache / working on bikes is therapeutic just like riding them
Old 02-16-2020 | 08:49 PM
ExtremeBaggers
Originally Posted by Sqr
The entire front end of a 2014 is different with zero interchangeability with a pre 2013. Eg: a 2014 fender will not bolt to an earlier model, the lower tubes will not either as well as the inner fairing, or even the two piece light rack. The tubes are of a larger diameter and spaced out wider.
The wind shield and chrome trim are not interchangeable.
This even goes in reverse for earlier bike parts to a new 2014 model. Having said that you can switch the entire complete only front end between the years. The gooseneck bearings have a small modification and are adjusted differently, but the Frames are the same.
I’m told 49mm trees can not fit a older model bike. This is straight from a huge company that makes trees
Old 02-16-2020 | 08:50 PM
ExtremeBaggers
you post this on everyone’s fairing swap thread.
Quick Reply: Can the 2015 Road Glide Fairing bet retrofitted to 2013 and earlier?
