Big bore or cam?
Big bore or cam?
I only run my '07 motor between 1500 and 3500 rpm.I'm only concerned with power in this rpm range, and I don't care at all about power above 4000 rpm. To improve low-end pull, is it better to just make the motor bigger or optimize existing motor for low-end umph with a cam?
In other words, if I rode a bike with the big borew/stock cam and another stock 96 w/touring cam, which would pull harder at low rpm?
Please forgive this stupid question, as I'm absolutely not a mechanic: If I pay the dealer to install a big bore, are they already into the engine enough that I would save some labor to have them install a cam at the same time? Or are they totally different installs with no economy on labor cost to do both at the same time?
RE: Big bore or cam?
Hard to tell. Usually stroking an engine increasses tourque more than an over bore would. My 01 Ultra has a 95" kit and I recently installed Andrews 26 cams. The 95" kit made it stronger than other 88" Twin Cams, but the cams made it a beast. The 26 is only slightly bigger than the stock cams but they made a huge difference, but not entirely in the range your seeking. It does it's best work above 3k.
If you want the most bang in the range you specify, I'd go big bore, Air intake, and an exhaust only slightly less restrictive than stock (freeflowing/loud pipes kill bottom end), maybe something like the SE touring pipes.
Re'
[/align]
I want to do the same, cams only for now.
Is the Andrews 26 the most agressive you can get with an88that has aBig Sucker, PCIII and BassaniTrue Duals? I would prefer not to have to buy cams twice when I do the other stuff next winter. Can I do gear driven cams as well?
ORIGINAL: jeepster09
It's not the most agressive, but in that RPM range is probably the best for bagger. Decide on what your final goal is before doing any motor mods. Do you want high horsepower and torque? Lots of torque...or? Again in that RPM range the Andrews is very hard to beat.
ORIGINAL: Kern
When the motor is complete I will be looking for bothTQ and HP. I was hoping for now that new cams would give me that little bit of extra TQ. I was talking with a bud about it, he said with what I have (air, exhaust etc)I could even go with the 37G. I just repliedwith a"aha". I don't know if he is blowing smoke or not. Is he?Anyone know who has a competitive online price?
