Oil in starter
Oil in starter
Here is the issue,
I have went thru 3 starters all with the same issue, loaded full of primary oil..
now the primary is filled to mfg specs, and the O ring is intact around the nose of the starter, what gives?
i have tried to run a bit less oil, dont work,
totally clueless on what is causing this to happen
Jimbo45
09-02-2015 07:55 PM
