Exhaust Heat Wrap Question/Advise
I am looking to wrap my right, rear exhaust down pipe due to the fact that its very close to the passenger right floorboard and its uncomfortable for my wife. So I would like your advise on whether or not wrapping the rear down pipe with "header wrap" will negatively affect performance......figured I'd wrap the "header" and just cover it with the existing chrome shield. Will this lower heat enough to make my wife comfortable? Thanks
It won't hurt performance.Whether it will reduce the heat enough to make your wife comfortable there's only one way to find out.Once you do it do not let your bike sit wet the wrap will hold water and accelerate rust.Easy enough to fix though, just run it for a few minutes after you wash it or ride in rain.
Having used it for a season I'm not a believer. I didn't use heat shields, just the wrap. The end result was increased discomfort for me and Cheryl. It was friggin hot! My hope was that the wrap would prevent melted rain pant legs. Nope. Didn't even slow it down and left a nice plasticky mess all over the wrap....which eventually burned off because, yes, it's so damn hot. When I took the wrap off I noted some pitting and discoloration (on the pipe) in the pattern of the wrap. I did as advised, ran it after it got wet. But still, it seemed to have aged the pipe faster than is normal.
It may be the case that not all wraps are created equal. But if I were you I would send the pipe out to be ceramic coated. I've heard good results can be had. Maybe search the topic.
Received 5,424 Likes
Get the true dual headers from Vance & Hines, that solved the problem. Plus you end up with two header pipes with two heat shields, not that mess that the factory gave you stock on the bike with a zillion pieces and shileds.
I did it four years ago and the heat is greatly reduced. Only thing is it will make your bike louder. Good or bad depending on your preference.
Best regards,
Ed
Maybe you should add another riding condition - only ride when its nice and sunny AND really cool.
