Help headlight removal..
Ok I'm replacing the do hickies for the fairing. Trying to disconnect the headlight so I can remove the fairing. Should be able to squeeze the tabs and pull apart..... Well that's not working and before I freak out and break something I thought I would come here for advice. So is there a trick to getting the light to unplug???
Thanks
Thanks
You can also go at it from the front.
Take the chrome ring off, then take out the 3 screws holding the headlight in the fairing.
The headlight will fall out in your hands.
You might be able to get a better grip on the plug through the front hole?
Might be a little corrosion on the prongs that could be holding it back.
