Can I remove baffle from cross over side only?
My SE touring muffs are too quiet. I pulled the innerds out and it is totaling encapsulated. No getting to anything in there. Is it possible to remove the baffle from the cross-over side only for additional sound and retain sufficient back pressure? It seems as though there is not much air flow through that left side anyway.
RE: Can I remove baffle from cross over side only?
on stock pipes and slipons...
70% exhaust on right side
30% on left side
DO NOT REMOVE ONLY THE BAFFLES FROM ONE SIDE.
either get a different set of slip ons or a set of true dual pipes or 2 into 1 pipes.
think about it like this...stop up one side of your nose ...now try to breath or blow your nose...not real easy, HUH. Same thing on removing only one baffle.
30% on left side
Hes removing a baffle not plugging one. At the very least he's going to have more flow, not less...
Regardless, new slip ons are the better option... but I like the curiosity, wonder what it would do to it and how it would sound...
lp
lp
ORIGINAL: jbhawley
30% on left side
30% on left side
ORIGINAL: ken thompson
I have plans to design new baffles 2 1/2 and re-think the flow characteristic of it...
Without the baffle it has a really rich low tone, but I'm sure at 60-70 it would be crazy loud... and around here, if a LEO gets behind you and sees no baffle, Ticket Time...
Are you saying remove just the left or left also?
I would be curious if anybody has removed the baffles on any 07 stock exhaust.
When I had my 05 Suzi Boulevard C50, I removed the baffles and loved the increase sound. In addition, no remap was needed. Curious if I could do the same thing to my SG.
[align=left] [/align]
I'm saying just removing the left baffle since it get onl a small fraction of the exhaust flow anyway. Should retain back pressure and gain noise. I guess the only to tell is to try it. I just didn't want to burn anything up. Do you think any damage could result?
ORIGINAL: sweetlu
[align=left][/align]
wideglideCVO
Exhaust System Topics
19
01-08-2023 02:57 AM
lp77
07-17-2014 09:14 AM
ken thompson
04-07-2007 10:47 AM
