Transfer & Cam Chain Tensioners
You're probably referring to the Primary chain tensioner and the cam tensioners. In my experience so far, the cam chain tensioners on your bike are most likely fine up to about 50,000 miles at which point they'll probably still be fine, but worth a look. The same can be said of the primary chain tensioner, although they tend to run a bit tight. Chances are that the primary tensioner itself will be fine for 50,000 too, but an inspection more frequently might be a good idea if only to check chain tension.
What happened on 07 and later cam chain tensioner that they are no longer a problem? Please elaborate. I have a 2010 Ultra with 23k miles and was going to include checking the cam chain tensioners and primary chain tensioner in my next oil change, maintenance checks.
I think he means primary chain.
