HD Timer Cover with "Bar & Shield" Logo
Old 04-07-2007 | 10:53 AM
Lu's Avatar
Lu
Default RE: HD Timer Cover with "Bar & Shield" Logo
That sealed it for me. I was thinking of getting that cover. Thanks for the pic
[align=left]That's P/N 32492-04, right?
In addition, when you remove the OEM timer cover, will any fluids leak out. If so, do you need a gasket?
[/align][align=left] [/align]
Old 04-07-2007 | 10:55 AM
buzzlink's Avatar
buzzlink
What's an easy-brake?
Old 04-07-2007 | 11:32 AM
Wally's Avatar
Wally
Don't know the part #.
I didn't instal the cover, the tech that installed my cams and gear drive did it.
Oil might leak out, but, if you ride your bike up onto a 2x6 it will lean over quite a bit further and most of the oil will flow to the left side of the bike.
It's probably a god idea to have an assistant to hold the bike for a few minutes when you do it.
If you don't have a manual, get one.
Old 04-07-2007 | 11:37 AM
Wally's Avatar
Wally
The ez-brake is an aftermarket rear brake lever for HD Dressers.
They may make them for other models, not sure.
If you look at my rear brake lever in the photo above you will see it has a dogleg type shape to it. This moves the pad down and forward, where it should be.
Very comfortable and it is exactly were it should have been put from the factory. Get one you will love it!
Here's the link,
http://bellsouthpwp.net/e/z/ezbrake/intro.htm
Old 04-07-2007 | 11:39 AM
electaRICK's Avatar
electaRICK
theres no oil behind that cover,,,ez shcmeezy install
Old 04-08-2007 | 06:32 PM
buzzlink's Avatar
buzzlink
Thanks Wally. I'll look into it.
chap!
02-22-2013 10:19 AM
barrygreen
04-20-2012 07:22 AM
hemel
11-22-2010 05:30 PM
schumacher
04-20-2010 07:49 PM
vickon
03-28-2010 07:27 PM
Quick Reply: HD Timer Cover with "Bar & Shield" Logo
