Please help front wheel noise
Yesterday I noticed a humming noise coming form what seems to be my front wheel. I got a 12 Limited with 12K miles. I turned the radio off and put the bike on neutral and I can still hear this noise.
I checked everything in the front wheel and do not see any obvious problems. Disks are not loose, brakes are not stuck, no grease signs of Chinese bearing that are about to fail. Could it be tire cupping? I get this noise after 35 mph all the way up to any higher speed. What do you experts think? Thanks in advance
If it is when going straight then it probably is the cupping in the tires. Mine only does it when cornering with a pretty agressive lean. This is the second front tire from two different maufactures and I have the same humming/whining vibration. The first was a Dunlop and the second a Michelin CommanderI.
