Foot board hex bolt size - RKC
I have a '99 RKC. Need to remove the right side foot board in order to remove the exhaust. What size are the two hex bolts that hold the foot board to the frame? I have a metric set, 10mm is too big, 8 is too small, 9 is not included in the set. Maybe 3/8?
Thanks
Thanks
get over to Sears and get a tool set on sale.
for SAE fasteners, the bolt is measured by the shaft size- and the head size ( what size wrench) is always 3/16" larger.
so for example my floor boards are held on with 1/4" NC bolts- which take a 7/16" wrench.
SAE generally uses 2 thread pitches National Coarse ( NC) and National Fine ( NF)- with practice you'll be able to tell by eye, they can;t be mixed.
You'll kinda need SAE wrenches/sockets and some metric to work on your Harley.
also some SAE allens and some Torx- esp the T27 used for the primary cover
mike
mike
ashmarc
07-18-2010 10:05 AM
