2011 Street Glide Will NOt Start Unless I pull the Clutch In
Old 07-30-2014 | 06:21 PM
casique's Avatar
casique
Default 2011 Street Glide Will NOt Start Unless I pull the Clutch In
Today I performed the 10K service myself using the SHOP MANUAL.
Took the bike out to warm up the oils. Came back and changed all the oils, and adjusted the clutch. I've done this many times.
Tried to start it after I was done and nothing. Put new batteries in the fobs and still no start. The fuel pump and all the lights came on, but dead otherwise.
Pulled in the clutch lever and it started and ran fine, even after letting the clutch lever out.
What's going on here? Thanks.
Old 07-30-2014 | 07:27 PM
dawg's Avatar
dawg
There is a switch in the clutch perch....just like the brake switch on the brake side. You probably dislodged it a bit during your clutch adjust. Revisit that area and check. The switch will not allow the bike to start in gear without clutch being pulled in.
Old 07-30-2014 | 07:30 PM
jstrenn's Avatar
jstrenn
Make sure the Tranny is in neutral and you are getting a neutral light. Won't start in gear unless the clutch is pulled in.
Old 07-30-2014 | 07:58 PM
casique's Avatar
casique
Yes in neutral and have light. Might just redo the clutch adjust.
Old 07-30-2014 | 10:55 PM
arlinsg's Avatar
arlinsg
Clutch adjustment needs to be done when the bike is cold.
Old 07-31-2014 | 12:55 AM
karbar99's Avatar
karbar99
Jiffy Stand Down???
Old 07-31-2014 | 07:31 AM
skratch's Avatar
skratch
Originally Posted by karbar99
Jiffy Stand Down???
thats only a factor in the international bikes. thankfully, we haven't got to that point here in the states.
Old 07-31-2014 | 12:55 PM
casique's Avatar
casique
Yes bike was cold, I used the shop manual... Is it possible that I damaged the clutch switch. The small switch beind the clutch lever?
Old 07-31-2014 | 06:52 PM
skratch's Avatar
skratch
all that switch does is allow you to start the bike in gear with the clutch lever being pulled in. if you damaged the switch, you would have the symptom of not being able to start in gear with the clutch pulled. it should have no effect on whether or not it will start in neutral, clutch pulled or not.
Old 08-01-2014 | 06:47 AM
Jrsess's Avatar
Jrsess
Absolutely!!! JR
