Hot bike questions...
Old 07-26-2014 | 04:47 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
no parade mode on 06, late 07 it first came out as a download then on the 08.
Old 07-26-2014 | 05:32 PM
aceross's Avatar
aceross
Stage IV
This is out of the 06 owners manual. Early version of engine temperature management.
Injected Twin Cam High Temperature Idle
Fuel injected Twin Cam engines use a four phase heat management system to reduce engine temperature under extreme conditions. A rider with a very hot engine may notice the affects of this four phase heat management system and incorrectly assume an idle problem exists.
Phase 1: When the engine temperature sensor signals that the cylinder head has reached approximately 266° F (130° C) the ECM will gradually reduce engine idle speed until the engine temperature drops or the engine reaches 900 RPM.
Phase 2: If engine temperature reaches 293° F (145° C), the ECM will gradually reduce engine idle speed until the engine temperature drops or the engine reaches 800 RPM.
Phase 3: If the engine temperature reaches 322° F (161° C), the ECM richens the air/fuel ratio to provide additional cooling and advances the spark timing 10°.
Phase 4: If the engine temperature reaches 331° F (166° C), fuel injector pulses (2 of 8) are randomly interrupted. The air drawn in and expelled helps cool the engine further. Since there is no combustion it would be perceived as a misfire. This fourth stage will only happen when the motorcycle is stationary.
If necessary, engine idle speed will be increased during all Phases to maintain proper battery voltage.
Old 07-27-2014 | 08:19 AM
glide2005's Avatar
glide2005
I stand corrected, I learn something new everyday on this forum, I love it.
94 ultra
06-15-2017 07:24 PM
Slow Road
2014-2023 Touring Models
85
07-14-2015 10:59 PM
toastman
Oil Archive (no new posts)
27
07-12-2010 02:40 AM
klaybus
11-29-2008 06:03 PM
needadyna
16
06-07-2006 04:04 PM
Quick Reply: Hot bike questions...
