Side play on shift rod lever
Old 07-25-2014 | 08:08 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by DeputyLoud
...mostly the toe shifter since that obviously gets used twice as much.
Please explain.
Every gear I shift up (heel) I have to shift down (toe)...
I don't downshift twice as much as I upshift.
Old 07-26-2014 | 08:40 AM
marvincbr's Avatar
marvincbr
Originally Posted by GriffinDenim13FLHX
$225 plus S&H is kinda steep...
I was having the same issue with mine. The bolt that secures the lever to the spline had bad threads at the place of contact with the spline, I would assume from coming loose and vibrating. I replaced the screw with a new one from the dealer, used a little loc tite. So far, so good.... $1.50 for the screw
Old 07-26-2014 | 12:03 PM
lionsm13's Avatar
lionsm13
That ($225) is a tad steep +S & H. WOWOW!!
For that kinda ching it should never ever have any issues!!
Old 07-26-2014 | 12:27 PM
fullautomike's Avatar
fullautomike
I had to do the same thing. Except I got the screw from a hardware store. That was last fall 12k miles ago. No problems since. Easy fix
Mikey V
09-23-2013 03:10 PM
Hoblick
08-29-2011 09:32 AM
Theride
08-04-2011 08:34 PM
greybeard2009
07-31-2010 08:47 PM
sporty87
08-11-2009 01:29 AM
Quick Reply: Side play on shift rod lever
