Removing rear signal lights?
I have a 2014 Canadian Street Glide which has the rear fender center tail/brake light and signal lights bar.Last week I purchased the HD bag mounted run/brake/signal lights.Now I want to remove the signal light bar.But I still need a mount for the rear tag and a light for it.And when I remove the bar there will be 2 exposed indented holes on either side of the tail light that will need to be covered.Any suggestions?
Dan.
Dan.
Dan.
Dan.
I used a belt buckle and painted it black to hide the three holes above light where the plate was stock
Hope you can tell by the pic so maybe enlarge it if you can
Here is a pic of what i did. My license plate was on top so I moved it below and bought a lighted LED frame from Custom Dynamics. The indents I just inserted some spikes and it turned out sweet......
Through the two existing holes under tailight where the turn signal bar was mounted on fender. Had to use a flat bar with holes in it (bought at Westlake Hrdwr) as it bends really easy to contour the the fender.
